Previous Topic: Status (Group)Next Topic: Status/Output Files (Table)
Status/Input Files (Table)
The Status/Input Files table contains the following information about the SCAP data stream files that are processed:
Attribute
Type
Description
Name
string
Specifies the file name of the input SCAP data stream
Type
string
Specifies if the input file is an XCCDF or OVAL file
Location
string
Specifies the location of the input file
Timestamp
string
Specifies the date and time when the input file was created
Size
int64
Specifies the size of the input file in bytes
