Previous Topic: Status/Output Files (Table)Next Topic: General/Identity (Optional Group)
General (Group)
The General group contains the following information about the benchmark and the test:
Attribute
Type
Description
ID
string
Specifies a unique ID for the test result reported in a particular inventory file
Profile
string
Optional. Specifies the ID of the profile applied during the benchmark application
Start time
string
Specifies the time when the benchmark application or compliance check started
End time
string
Specifies when the check ended. Both start and end times are given as strings in the format used for XCCDF files
Benchmark Ref
int64
Specifies a reference (filename or link) to the used XCCDF file
Title
string
Optional
Remark
string
Optional
Organization
string
Optional. Specifies the organization that is responsible for the results
Organization_2,
Organization_3...
string
Optional. Specifies additional organizations. If the additional organizations are hierarchical then they must appear in high-to-low order
