The executable performing the actual SCCM extraction work, am_sms_ex.exe, may be launched manually for testing or debugging purposes.
The available command line parameters are:
Specifies the name or address of the SCCM Site server from which to extract. Defaults to localhost when not supplied.
Specifies the user name to use when connecting to the server. Defaults to current user.
Specifies the password to use (in plain text). Only used when a user name has also been given.
Identifies the site ID of the SCCM installation to contact. Only required if the server contains more than one SCCM installation.
Indicates the directory in which to place any XML files that are produced.
Extracts software information.
Extracts hardware information.
Extracts the last logged on user for each computer as a related asset.
