Previous Topic: SCCM Converted Data in the CA MDBNext Topic: Command Line Utility am_sms_ex.exe
Diagnostics and Tracing
The common DSM tracing system is used to record detailed information while a CA Asset Converter for Microsoft SCCM task is being run. If the appropriate configuration step has been performed, the trace file used is TRC_SMSEX.log. Otherwise, it is directed to the TRC_UAM.log file where it may be interspersed with information from other DSM components.
