Previous Topic: Create a CA Asset Converter for Microsoft SCCM Engine TaskNext Topic: Description
Task Properties
A CA Asset Converter for Microsoft SCCM task is configured either during its creation in the New Task Wizard or, for an existing task, through its Properties dialog. In either case, the configuration GUI is the same except that you navigate between the pages using the Next and Back buttons whereas the Properties dialog has tabs.
