The cacertutil import command imports a certificate into the CA ITCM comstore.
Important! This has to be done on the computer where the administrator plans to perform the signing of the inventory files and must be done before the signing.
Note: For more information about cacertutil commands, see the Command Line Reference Guide.
cacertutil import -i:filename -ip:passphrase -t: tag
Specify the filename of the certificate to be imported.
important parameters:
Specify the passphrase and store encrypted in comstore.
Specify a tag name.
Note: You must use the same tag name specified in the –t parameter on the computers that verify and sign the inventory files.
Example: Import a Certificate
cacertutil import -i:C:\AssetCollectorCert.p12 -ip:password -t:AssetCollector
