The cacertutil create command creates a certificate.
cacertutil create -o:filename -op:passphrase -s:subject -od:filename
Specify the output filename of the certificate.
Specify a passphrase to encrypt the certificate.
Specify the subject name to whom the certificate is issued.
Create a DER encoded file with just the public certificate.
Example: Create a Certificate
This example creates two files AssetCollectorCert.p12 and AssetCollectorCert.der. The .der file contains only the public part of the certificate and must be copied on to the Asset Collector computer where the signature is to be verified.
cacertutil create -o:c:\AssetCollectorCert.p12 -op:password -s:”CN=AssetCollector,O=Computer Associates,c=US” -od:c:\AssetCollectorCert.der
Note: For more information about cacertutil commands, see the Command Line Reference Guide.
