The cacertutil import command imports the public key on the Asset Collector server to the CA ITCM comstore.
cacertutil import -i :filename -t:tag -it:certificatetype
Specify the filename of the certificate to be imported.
important parameters:
Specify the type of certificate to be imported. Valid options are X509V3 or PKCS#12.
Default is PKCS#12.
Specify a tag name.
Note: For more information about cacertutil commands, see the Command Line Reference Guide.
Example: Import the Public Key
cacertutil import -i:C:\AssetCollectorCert.der -t:AssetCollector -it:x509v3
