Built-in export modules for various CSV and HTML formats make it easy to export the results for use in external tools. All exports can be customized from the GUI, and individual customizations are saved with each scheduled report, to make publishing of scheduled reports very flexible. To export the results, right-click the result and select Export, the required export format.
