The basic format of a reporter result set consists of two tables in the database: one containing rows of objects, for example, assets, and columns corresponding to the fields included in the report, and one supplying meta data for the result set, such as the full names of included inventory items and more. The later is referred to as the “map-table,” whereas the first mentioned is considered the actual result table.
