Any result set can be viewed entirely in the GUI simply by selecting it in the tree view. The Information pane shows all assets matching the criteria of the report definition. The Information column views common result information and provides the ability of filtering the result (can be toggled on or off to compare the full result set with the subset defined by the filter) or viewing the legend of a field.
