Previous Topic: Setting the DECwindows Destination for DECnet TransportNext Topic: Console Manager Callable Interface
Console Manager Commands Quick Reference
The following table lists of all the commands used by Console Manager from the command line. Commands shown in bold are used for managing Console Manager.
Command
What It Does
See
CONSOLE ARCHIVE
Archives log files
Managing Console Manager
CONSOLE CONNECT
Starts the connect interface from the shell or system prompt
Using Console Manager from the Command Line Interface
CONSOLE C3
Starts the C3 interface on workstations
Using Console Manager from the C3 Interface
CONSOLE STATUS
Displays the status of Console Manager components and serviced systems
CONSOLE DIALOG
Performs a dialog with a specified serviced system
CONSOLE EDIT
/INTERFACE=
DECWINDOWS
Starts the configuration editor using the C3 interface
Modifying the Configuration Database
CONSOLE EDIT
/INTERFACE=
CHARACTER_CELL
Starts the configuration editor using the character cell interface
CONSOLE EVENTLIST
Starts an Eventlist interactively
Supplied Action Routines
CONSOLE MONITOR
Starts the monitor interface on character cell terminals
Using the Monitor Interface
CONSOLE RECONFIGURE
Reconfigures the running Console Manager software
@SYS$STARTUP:
CONSOLE$MANAGER$SHUTDOWN
or
CONSOLE SHUTDOWN
Shuts down the Console Manager software
@SYST$STARTUP:
CONSOLE$STARTUP.COM
Starts the Console Manager software
CONSOLE VERIFY
Verifies the integrity of the log and archive files for the serviced systems and optionally repairs them
CONSOLE WATCH
Logs console data to hardcopy devices
CONSOLE EXTRACT
Outputs console log data for a specific period of time to a file or the default output device
