Previous Topic: Action RoutinesNext Topic: The C3 Interface
The Command Line Interface
When Eventlist is started from the command line, your customizations are saved in the following locations:
SYS$LOGIN:
The filename is CONSOLE$EVENTLIST.DAT
The location of the interactive Eventlist saved settings may be customized through the use of the following environment variable or logical name:
CONSOLE_USER_DEFAULTS
For example, to save your interactive Eventlist setting in the subdirectory Console Manager from your login directory, first create the Console Manager subdirectory, and then enter the following in your login script:
DEFINE/JOB CONSOLE$USER_DEFAULTS
SYS$LOGIN_DEVICE:[home_directory.CONSOLE]
