Previous Topic: Viewing the Distribution of Event PrioritiesNext Topic: Action Routines
Saving Your Changes to Eventlist
After you make any changes, you must save the changes so that they can be implemented when you restart Eventlist.
To save your changes, pull down the Options menu and choose then Save Options menu item.
The file location for your saved settings depends on how Eventlist was started:
