Using the Eventlist Interface › Customizing Eventlist › Change the Bell Volume Settings of Event Priorities
To change the bell volume for the various event priorities
- Pull down the Options menu and choose the Volume ... menu item.
- The Volume Options dialog box is displayed.
- Move the slider bar for the event priority until the required volume setting is displayed. The setting is in the range 0 to 100.
- Click OK.
- Pull down the Options menu and choose Save Options to save your settings.
Copyright © 2010 CA.
