The tasks you can do with Eventlist depend on how it is started. The shows the tasks available depending on the method used to start Eventlist.
Task |
Available Interactively |
As An Action |
See Section |
Restart Eventlist to make use of any customizations you have made |
YES |
NO |
Restarting Eventlist |
Disconnect Eventlist from ENS to prevent new events being displayed |
YES |
NO |
Disconnecting Eventlist from ENS |
Reconnect Eventlist to ENS to continue to receive events |
YES |
NO |
Reconnecting Eventlist to ENS |
Customize Eventlist |
YES |
YES |
Customizing Eventlist |
Manipulate the displayed events |
YES |
YES |
Manipulating Events |
Stop events from being displayed based on a filter or event priority |
YES |
NO |
Stopping Events From Being Displayed in the Eventlist Window |
View the distribution of event priorities |
YES |
YES |
Viewing the Distribution of Event Priorities |
Save changed options |
YES |
YES |
Saving Your Changes to Eventlist |
Restore default option |
YES |
YES |
Restoring the Default Options |
By default, the list of events scrolls automatically when a new event is received. If you have scrolled to previous events in the list, and you do not want the list to scroll, deselect the Auto-Scroll to new messages option to turn this function off.
When a task is not available, then the corresponding menu option is grayed out.
Copyright © 2010 CA.
