Previous Topic: Filtering Events from a Group of Systems Depending on the TimeNext Topic: Using the Eventlist Interface
Filtering Duplicate Events in a Group of Systems
This scenario describes how to receive events from a group of systems, but avoiding multiple notifications of the same event when that event occurs within a specified time.
The Scenario
A security administrator needs to know about all events that have the class Security from the Cruet group. The administrator wants the events to be sent by an eventlist to the workstation admin.reo.dec.com. However, if the same event recurs within 60 seconds, it is to be ignored. Notification begins again when that event occurs more than 60 seconds from the original notification.
One action, one filter and one dispatch are required. The action will use the eventlist action routine to dispatch the events.
Assume that the events, classes and serviced systems have already been created in the configuration database, and that the systems are in a group called Cruet. Also, the DECwindows Motif transport is TCP/IP.
The Solution
To set up the filtering mechanism for duplicate events from a group of systems, do the following:
Step
Action
CLI
C3
1.
Start the configuration editor
Starting the Configuration Editor in Chapter 4, “Modifying the Configuration Database”
2.
Create an action with the following attributes:
Name Enter Security
Information Enter Security events on the Cruet Group
Command Enter: CONSOLE$EVENTLIST
Action Type Select the “ALL events and EACH userdata item” option
Parameters
To Pass Select Userdata only, deselect all others
To Action
Adding Actions in Chapter 11, “Setting Up the ENS Components”
3.
Create a filter with the following attributes:
Name Enter Security
Event Set to 60 seconds
Interval
Events Deselect All Events
Classes1 Deselect All Classes, and select only the Security class
Systems Deselect All Systems
Groups Deselect All Groups, and select only the Cruet Group
Subsystems Select All Subsystems
Priorities Select All Priorities.
Adding Filters and Dispatches in Chapter 11, “Setting Up the ENS Components”
Adding Filters in Chapter 11, “Setting Up the ENS Components”
4.
Create a dispatch for the filter with the following attributes:
Action to Enter Security
Dispatch
Userdata Enter admin.reo.dec.com 0 0 tcpip
Select Execute at all Times on All Days
Adding Dispatches for Your Actions in Chapter 11, “Setting Up the ENS Components”
