Previous Topic: Filtering for a Specific Event PriorityNext Topic: Filtering Duplicate Events in a Group of Systems
Filtering Events from a Group of Systems Depending on the Time
This scenario describes how to receive events from a group of systems at a remote site, both during working hours and during non-working hours.
The Scenario
An operations supervisor based in London, England, needs to know about all events on the systems in the Sydney Datacentre in Australia. The supervisor needs to be notified in two ways, depending on the day and time:
Two actions, one filter and two dispatches are required. However, only one action need be created, since the existing Mail action can be used for dispatching events during non-working hours.
Assume that the events, classes and serviced systems have already been created in the configuration database, and that the systems are in a group called Sydney. Also, the DECwindows Motif transport is TCP/IP.
The Solution
To set up the filtering mechanism for specific times of the day, do the following:
Step
Action
For Command Line Interface
For C3 Interface
1.
Start the configuration editor
Starting the Configuration Editor in Chapter 4, “Modifying the Configuration Database”
2.
Create an action with the following attributes:
Name Enter Sydney
Information Enter Events from the Sydney Datacentre
Command Enter: CONSOLE$EVENTLIST
Action Type Select the “ALL events and EACH userdata item” option
Parameters
To Pass Select Userdata only, deselect all others
To Action
Adding Actions in Chapter 11, “Setting Up the ENS Components”
3.
Create a filter with the following attributes:
Name Enter Sydney
Events Select All Events
Classes1 Select All Classes
Systems Deselect All Systems
Groups Deselect All Groups, and select only the group Sydney
Subsystems Select All Subsystems
Priorities Select All Priorities.
Adding Filters and Dispatches in Chapter 11, “Setting Up the ENS Components”
Adding Filters in Chapter 11, “Setting Up the ENS Components”
4.
Create a dispatch for the working hours with the following attributes:
Action to Enter Sydney
dispatch
Userdata Enter opsmgr.lon.dec.com 0 0 tcpip
Deselect Execute at all Times on All Days
Dispatch See the following figure
Hours... for settings
Adding Dispatches for Your Actions in Chapter 11, “Setting Up the ENS Components”
5.
Create a dispatch for the non-working hours with the following attributes:
Action to Enter Mail
dispatch
Userdata Enter opsmgr@opsmgr.lon.dec.com
Dispatch See the last figure in this section for the
Hours... settings
The following figure shows the settings for dispatching events during working hours.
The following figure shows the settings for dispatching events during non-working hours.
