Before you can modify or delete entries in the configuration database, you must have the Edit Configuration data privilege set in your user entry.
To modify a filter, choose the Edit, Filter Show/Modify submenu, and then follow the instructions for adding a filter shown in the section, Adding Filters, earlier in this chapter. You can modify only a subset of the filter attributes. The attributes that can be modified are:
If you want to modify more than one filter, then click Apply instead of OK This displays the Filter dialog box, but does not close the Select Filter dialog box. When you have changed the filter, you can now select another filter from the Select Filter dialog box.
To delete a filter, choose the Edit, Filter Delete submenu, select the filter to delete, then click OK.
If you want to delete more than one filter, then click Apply instead of OK. The Select Filter dialog box is not closed, and you can now select another filter to delete.
Copyright © 2010 CA.
