Previous Topic: Change the Color of Group IconsNext Topic: Change the Color of Peripheral Icons
Change the Color of Serviced System Icons
To change the color of serviced system icons
  1. Pull down the Options menu, and choose the Colors, System Foreground submenu This displays the System Foreground dialog box.
  2. Select the color you require, then click OK.
  3. Choose Save from the Options menu to save the modified display.
