Customizing Console Manager › Customizing Your C3 Display › Change Icon, Window and Label Colors › Change the Color of Group Icons
To change the color of group icons
- Pull down the Options menu, and choose the Colors, Group Forground submenu. This displays the Group Foreground dialog box.
- Select the color you require, then click OK.
- Choose Save from the Options menu to save the modified display.
Copyright © 2010 CA.
