To examine events that have already occurred on a specific serviced system
Alternatively, double click the left mouse button on the icon representing the required serviced system. You can only do this if you have set up this facility for showing event history as part of your customized setup. The chapter Customizing Console Manager explains how to do this.
The system's icon is automatically reset to the default neutral color.
If you attempt to view events for a system that is currently being archived, then the following messages are displayed:
Archive already in progress
If an archive is started for a system that for which you are currently viewing the event history, then the event context window is cleared, and the following message is displayed:
System is being archived
Copyright © 2010 CA.
