To output live console data to a printer or terminal connected to an asynchronous device, or to a file
If you want to watch a subset of systems, then make sure the Select All Systems option is deselected, and click the systems you want to watch from the list available.
If you want to watch all systems, select the Select All Systems option.
If you want to output to a... |
Then... |
File |
Do the following: |
a. |
Select the Output to File: option. |
b. |
Enter the file name in the Output Filename field. |
Port or terminal device |
Do the following: |
a. |
Select the Output to Port: option. |
b. |
Enter the port name or terminal device in the Port Name field. |
c. |
Select the appropriate Port Speed. |
d. |
Select the appropriate Port parity. |
e. |
Select or deselect the 8-bit ASCII option. |
This invokes the watch interface.
To cancel this operation, choose the Stop submenu item from the Watch... submenu on the Console Manager menu.
If you start a watch for a system that is currently being archived, then there will be no output from the system until the archive finishes. When the archive finishes, the following message is displayed:
Archive completed on system-name - Watch output resuming.
If an archive is started for a system that is currently being watched, then the watch output is suspended while the archive is in progress, and the following messages are displayed:
Archive started on system-name - Watch output suspended. Archive completed on system-name - Watch output resuming.
Copyright © 2010 CA.
