Using Console Manager From the C3 Interface › What the C3 Interface Looks Like › The Group Window › Contents of the Group Window
The group window contains:
A matrix of icons representing each serviced system in a group.
- Two message boxes at the bottom of the display. From left to right, they display:
- The name of the system on which the most recent event occurred in this group.
- The name of the most recent event in this group.
- Five buttons at the bottom of the display. From left to right, they are:
- A mode change button, which allows you to change between Interactive and Edit mode.
- A Close button, which closes the group window.
- A Reset... button, which resets the icon colors of all systems in this group to their neutral color.
- A Find... button, which allows you to find a particular serviced system in this group.
- An Info... button, which you can use to display information about Console Manager.
Copyright © 2010 CA.
