The main window to the C3 interface gives you an overall picture of the environment you are managing and monitoring. It uses the information supplied in the configuration database for your user entry to create the display. It displays icons that represent groups, systems, or a mixture of both groups and systems that you have the privilege to access.
Copyright © 2010 CA.
