You can leave the C3 interface by using one of the following options on the File menu:
Exit - this saves any changes you have made to the display.
Quit - this exits without saving any changes you have made to the display.
To be able to exit or quit from the C3 interface, your username entry in the configuration database must have the privilege to exit C3.
Copyright © 2010 CA.
