The destination for your DECwindows Motif display must be set up before you start the C3 interface. See Appendix B, “Setting Up the DECwindows Motif Transport for the DECwindows Motif Interface,” for instructions on how to do this.
Also, ensure that the session manager security for the system you are setting the display from is enabled on your local workstation.
If the destination for your DECwindows Motif display is already set up, start the interface using the command described in Starting the C3 Interface.
Copyright © 2010 CA.
