Previous Topic: Information on EventsNext Topic: Verifying the Integrity of Log and Archive Files
Back Up the Configuration Database
We recommend that you export the configuration database at regular intervals. Use the export command from within the configuration editor to do this, as described in the chapter Modifying the Configuration Database.
Store this file offline as part of your regular Console Manager host backup strategy. You may also wish to export the database before and after you make any changes. This is discussed fully in chapter Modifying the Configuration Database.
