Previous Topic: Setting Up FailoverNext Topic: Step 1: Creating the Configuration
Establishing the Configuration
Before you use failover you need to configure your system. The configuration is a three-step process. The steps are as follows:
  1. Creating the configuration
  2. Exporting the configuration to a file
  3. Copying and importing the configuration file to the hosts
