You may need to create a new template configuration database file (for example, if the file already exists because you are reinstalling Console Manager).
To create a new template configuration database, delete your current configuration database file and build a new file as follows:
Run the configuration editor interactively and import the installation template file:
$ DELETE CONSOLE$DATA:CONSOLE_CFG.DAT;* $ CONSOLE EDIT/INTERACTIVE=CHARACTER_CELL IMPORT - CONSOLE$TEMPLATES:CONSOLE$CONFIG.PORT
Copyright © 2010 CA.
