When an automatic archive is activated, the value corresponding to the number of hours to archive is used to determine the amount of log data that will be moved from the active log file to the archive area specified in the archive directory field.
To set your own values, drag the slider bar to the number require. In the example in the section Setting Console Manager Characteristics, system the default number of hours' data to archive is being changed to 12 and the default archive directory to console$archive.
Use either the default archive directory, or a directory of your choice.
Note: Automatic archiving is a failsafe, and should not be relied on for archiving your log files. We recommend that you archive your log files regularly.
Copyright © 2010 CA.
