The file space checking attributes determine the frequency at which each system's logging area is checked to see if it has exceeded the defined filespace warning and filespace critical thresholds. These thresholds are entered as a percentage of total available logging space. If the warning threshold is exceeded, an event is generated. If the critical threshold is exceeded, an event is generated and an archive process is activated.
To set your own values, drag the slider bar to the number you require. In the example in the figure in the section, Setting Console Manager Characteristics, the default warning value is being changed to 80 and the default critical value to 95.
Copyright © 2010 CA.
