Set up the Environment › Identifying and Solving Connection Problems › Possible Solutions
Possible Solutions
If the connection is not working correctly, check the following:
- The LAT status is correct by using the LATCP utility.
- The DECconnect adapter is seated correctly.
- The DECconnect cable ends are connected correctly.
- The baud rates of the devices at each end of the cable are the same.
- The host system and terminal or console servers are using the same LAT group codes.
- The TELNET listeners on the terminal or console server are correctly configured.
- The port and server names in the configuration database match those set up on the terminal or console server (this includes case sensitivity of names).
- The terminal device assigned is of the appropriate type for the connection method being used.
- The PING utility, supplied as part of the TCP/IP Services for OpenVMS software shows that the TELNET terminal or console server is available on the network.
- The terminal server port is set up for remote access.
- The terminal server ports are correctly configured for XON/XOFF flow control.
- Before attempting to connect to a console with Console Manager using SSH, first validate the SSH configuration from DCL.
- Be sure the TCP/IP stack commands are initialized. Execute one of the following commands:
TCPIP Services
@sys$manager:tcpip$define_commands
TCPware
$ @TCPware:TCPWARE_COMMANDS
MultiNet
$ SET COMMAND MULTINET:USER.CLD
For best results, run this command in system-wide login procedure SYLOGIN.COM.
- Validate the SSH connection to your terminal/console server:
$ ssh <username>@<terminal/console-server>#<port number>
- Security settings external to the Console Manager database were changed. One example: the contents of an identity file used by CM for SSH connections. In this case, you need to shut down and then restart Console Manager in order to use the new settings for all affected connections.
For more troubleshooting information, see the DECconnect System Planning and Configuration Guide.
Copyright © 2010 CA.
