Set up the Environment › Connect Using LAT Transport › Configure for LAT
Configure for LAT
To configure your LAT connection
- Ensure that both the host system and the terminal or console server to be used reside on the same LAN or ELAN.
- Define the appropriate terminal server characteristics. To do this, see the manual for your terminal or console server. Set the characteristics the same as for a printer connection.
- Define the appropriate LAT group codes on the terminal or console server and on the host system's LAT configuration.
To set up the terminal server characteristics on a terminal or console server, refer to the documentation from your terminal or console server.
Copyright © 2010 CA.
