Previous Topic: Select the Language for the Installation DialogsNext Topic: Patch Product Creation Wizard
Copy and Change a Dialog Resource
To provide texts in different languages for multilingual setups, it is useful to copy and change existing dialog resources.
To copy a dialog resource
  1. Select the package in the project pane.
  2. Select a language entry on the Dialog resources tab in the subproject pane.
  3. Right-click the selected resource and select Copy from the context menu.
    The Resource dialog appears.
  4. Choose a new language from the drop-down list.
  5. Click Copy.
    The new dialog resource appears on the Dialog resources tab in the subproject pane.
To change a text in a dialog resource
  2. Select the resource to change on the Dialog resources tab in the subproject pane.
  3. Select an entry to change in the Dialog texts table in the GUI work pane.
  4. Right-click the selected entry and choose Change from the context menu.
    The Add/change text dialog appears.
  5. Edit the text in the Text input box.
  6. Click Add.
    The changed text is added to the dialog resource.
