You can create a multi language PIF package by using the multi_language.Any.@pif template. The multi language PIF package lets you specify the language to use for the product installation and also lets you select (or deselect) the language-specific components for the installation.
To create a multi language PIF package
The New package dialog appears.
Indicates the name of the PIF package. The package name can include up to 128 characters.
Indicates the version of the PIF package. The format of the version is M.m.b.r, where "M" signifies major, "m" signifies minor, "b" signifies build, and "r" signifies revision.
Indicates the UNIX or Linux platform specifying the hardware and operating system on which the PIF package can be installed.
Note: The option "Any" lets you install the package on all supported UNIX and Linux platforms.
Indicates the template used as a framework for the creation of an individual package setup. A template is formatted as a prototype file. Select multi_language.Any.@enu from the drop-down list.
The new package is created and appears in the project pane.
