Previous Topic: Delete a PIF PackageNext Topic: Create a Multilingual PIF Package
Import a PIF Package
Importing a PIF package means that you are importing an already built PIF package (xxx@pif) or a PIF prototype file (xxx@prm).
When you are importing an already built PIF package, you must specify a target directory where you want the imported PIF package to be extracted.
The name of the imported PIF package appears in the Project pane of the Packager GUI, and you can modify the imported PIF product.
To import prototype files
  1. Select Import from the File menu or right-click in the project pane and select Import from the context menu.
    The Choose a file dialog appears.
  2. Browse for one or more prototype files (*.@prm) or search for all types.
    Alternatively, you can specify the names of the prototype files in the File Name input field.
    Note: Only valid PIF prototype files are accepted for import.
  3. Click Open.
    The imported packages appear in the project pane.
To import an already existing PIF package
  2. Browse for the PIF package (*.@pif).
    Alternatively, you can specify the name of the PIF package in the File Name input field.
    Note: Only valid PIF packages are accepted for import.
  3. Click Open.
    The Import package dialog appears.
  4. Specify the location of the folder where you want the imported PIF package to be extracted.
  5. Click Import.
    The name of the imported PIF package appears in the Project pane of the Packager GUI, and you can modify the imported PIF package.
