Previous Topic: Specify the Input Order of a DialogNext Topic: Workbox
Installation Dialog Editor
The Packager GUI provides an installation dialog editor and several tools and features to modify standard installation dialogs to fit your needs or create individual new installation dialogs. The installation dialog editor lets you drag and drop dialog elements from a toolbox into a work area and customize the dialog elements through properties boxes.
Note: The drag and drop task involves the following steps:
  1. Select an element in the toolbox.
  2. Move the element into the dialog editor panel (work area) while pressing the right mouse button.
  3. Release the mouse button at the place where you want to put the element.
The installation dialog editor opens when you select a dialog on the Dialogs tabs in the subproject pane or right-click on the Dialogs tab and choose to add a new dialog.
The following screenshot shows a sample installation dialog editor window:
Screenshot displaying the Installation Dialog Editor
Whenever you want to see the current layout of selected dialog, for example, during dialog creation, click the Test dialog icon on the toolbar of the Packager GUI.
