Previous Topic: Progress BarNext Topic: Radio Button
Progress Label
PIF dialog editor toolbox icon for Progress label
A progress label shows information about the installation progress that changes during the installation process. The progress label usually leads a progress bar and informs the user about the current install action (for example, install, backup, remove) and optionally the installation phase, the name of the file or component currently being installed, or the elapsed installation time. You can drag and drop the progress label icon from the toolbox to the work area only if you have specified that you are creating a progress dialog, that is, the Presentation field in the Dialog properties is set to Progress.
The currently running installation action, the file being installed, the component name, and so on, are described through the following environment variables:
