Previous Topic: Progress AreaNext Topic: Progress Label
Progress Bar
PIF dialog editor toolbox icon for Progress bar
A progress bar shows the progress of the installation of a product or a component, or the overall installation progress. You can drag and drop the progress bar icon from the toolbox to the work area only if you have specified that you are creating a progress dialog, that is, the Presentation field in the dialog properties is set to Progress.
The installation progress of the current product or component is described through the following environment variables:
