How to Create and Deploy OS Images using a Linux-Based Boot Image › (Optional) Update Existing WinPE-based Linux OS Images › Update OS Images using DSM Explorer
Update the existing WinPE-based Linux OS images with the new template files to be able to use the new Linux-based boot image.
- (Optional) Verify that you have merged the custom changes, if any, to the new template files.
- Navigate to Software, Boot and OS Image Library, Image Prepare System, Update OS Image in the DSM Explorer.
The Update OS Image wizard appears.
- Follow the instructions in the wizard to update the OS image.
The OS image is updated and registered with the domain manager based on the options you have selected. Deploy the updated SD package on the other boot servers that stage the OS image that you just updated.
More information:
Make Boot and OS Images Available on Boot Servers
Updating Customized Files
