Previous Topic: (Optional) Add Additional Drivers to the Boot ImageNext Topic: Update OS Images using DSM Explorer
(Optional) Update Existing WinPE-based Linux OS Images
You can update the existing Linux OS images that use WinPE as the boot image to use the new Linux-based boot image for deployment. See the Compatibility Matrix available on support.ca.com for the list of Operating Systems supported.
Use the following methods for updating the OS images.
This updates the existing OS images with new scripts and utilities needed to work with the new Linux-based boot image and sets up the OS image to use this new boot image.
With the new boot image support, administrators do not have to copy syslinux manually in the OS Image.
