To restore the OS image on the model computer
Parameter |
Description |
OSImage |
Specify "getimage" or "getwepos" depending on the support OS type. |
BootSpecial |
Specify the required boot image. |
ImagexImage |
Specify the name of the backup image file to restore |
CreateImage |
Specify "restoreImageX" or "restoreGhost" |
RestorePolicy |
Specify the restore policy for the job. |
The job restores the OS image on the active partition of the model computer. After the image is restored, the model computer reboots and the status of the job is set to Stop in DSM Explorer. You can view the log file at <OSIM-imagestore>\images\<imagename>\<imagename>\images\<computername>\<$ImageXImage$n>\osim- restore.log
Note: If there is no active partition on the model computer, the job creates an active partition using the <OSIM-image store>\images\<imagename>\<imagename>\images\<name_of_model_PC>\ $ImageXImage>\$ImageXImage$.wp1 diskpart file, and installs the image in this new partition.
