Previous Topic: (Optional) Restore the OS Image on the Model Computer (Step 4)Next Topic: Create and Register the Golden Image as OSIM OS Image (Step 5)
Restore Policy
Restore policy defines the restore strategy for the RestoreImageX and RestoreGhost jobs for one target computer. You can configure the restore policy to specify the backup image that you want to restore on the target computer.
Following are the valid values for the $restorepolicy$ parameter:
Take the backupimage as named in $ImageXImage$" [0]
Specifies that the backup image with the name equivalent to the value of $ImageXImage$ parameter be restored on the target computer.
Take the newest backupimage with the base name $ImageXImage$" [1]
Specifies that the latest backup image with the base name equivalent to the value of $ImageXImage$ parameter be restored on the target computer. The backup image can have a trailing number if you have more than one backup image.
Take the second newest backupimage with the base name $ImageXImage$" [2]
Specifies that the next-to-last backup image with the base name equivalent to the value of $ImageXImage$ parameter be restored on the target computer. The backup image can have a trailing number if you have more than one backup image.
More information:
