You must run another OSIM backup job to capture the OS image using the specified imaging tool.
To create OSIM install jobs to capture an image
Parameter |
Description |
OSImage |
Specify "getimage" or "getwepos" depending on the support OS type. |
BootSpecial |
Specify the required boot image. |
ImagexImage |
Specify the name of the image file to create |
CreateImage |
Specify "backupImageX" or "backupGhost" |
BackupPolicy |
Specify the backup policy for the job. |
getimage.cmd copies the ImageX client to the new image directory, executes ImageX to capture c: partition of the model computer, and stores the images as a .wim file in the following path:
\\<OSIM-image store>\<imagename>\<imagename>\images\<computername>\ <$ImageXImage$n>\<$ImageXImage$n>.wim
After the image is captured successfully, OSIM job status in DSM Explorer is set to Stop. You can now create and register the OSIM OS master image for OS deployment. If you have taken a backup of the model computer, you can restore it now.
