Previous Topic: Deactivate Password CachingNext Topic: How Integration and Migration Works
Integrating with eTrust Access Control
CA NSM Security Management no longer provides security for logon authentication or for files. If you need this type of additional security, you may want to integrate CA NSM with eTrust Access Control (eTrust AC). eTrust AC protects enterprise assets including CA NSM assets, file-based assets, and authenticates logons.
You can migrate CA NSM 3.0 or 3.1 security to eTrust AC. When you install CA NSM r11.2, the installation process detects whether CA NSM 3.0 or 3.1 is enabled to use eTrust AC. If CA NSM 3.0 or 3.1 is enabled to use eTrust AC, CA NSM Security Management is not installed. Alternatively, CA NSM r11.2 includes a lightweight security engine for the protection of CA NSM assets only, which is provided if you do not want to install and migrate to eTrust AC.
Note: For complete information about CA NSM security migration and integration with eTrust AC, see the eTrust Access Control Getting Started guides, the eTrust Access Control Implementation Guide, and the eTrust Access Control Administrator Guides.
