Previous Topic: Override the Management Command Center User IDNext Topic: Integrating with eTrust Access Control
Deactivate Password Caching
The password cache file is used to save the user ID and password credentials that were used successfully to access a namespace. Therefore, the next time the Management Command Center is started, the saved credentials are used to access the namespace, and if they are still valid, the user does have to enter them again. The saved credentials are shared by all users of the Management Command Center on the same system, even if they use different profiles. Thus, password caching is not desirable if multiple users are running the Management Command Center on the same system.
To deactivate password caching, enter the following line into the ji.cfg file:
default.SEC.bypass_cache: 1
Passwords are not cached.
