eTrust AC r8 provides automatic integration with CA NSM using options when you install eTrust AC. You must install eTrust AC r8 before you attempt to migrate CA NSM 3.x security. After you migrate CA NSM 3.x security, you can install CA NSM r11.x.
If the CA Event Notification Facility (CAIENF) is running, sessfgate is automatically started or stopped whenever the eTrust AC services are started or stopped. If CAIENF is not running, eTrust AC does not start the sessfgate daemon. You must start it manually.
Note: After CA NSM Security Management is disabled and eTrust AC is started, the sessfgate daemon can accept API requests instead of the Secure Sockets Facility (SSF).
Copyright © 2010 CA.
