Previous Topic: Grant Non-Root Access to the Management Command CenterNext Topic: Deactivate Password Caching
Override the Management Command Center User ID
The Management Command Center maintains separate storage areas for its saved settings and bookmarks, indexed by user ID. When multiple users are running the Management Command Center while logged in to the same account (for example, UNIX/Linux root), you may want to override the user ID on the command line or provide a customized copy of the batch file (camcc on UNIX/Linux; tndbrowser.bat on Windows) for each user.
To override the Management Command Center user ID, append -profile:xyz to the shell command, where xyz is any unique string to use in place of the default user ID.
When you connect to a provider, the user ID and password are stored so that you do not need to supply this information the next time you use the Management Command Center.
Note: If you want to login as someone else, be sure that password caching is deactivated and, delete the password cache file from the %JI_SYSTEM%\files directory.
