You can control the refresh process for a selected node using the Refresh Timer dialog. The specified setting applies to the current node and to nodes of the same type as the selected one. The nodes in the trees have independent settings. The same applies to child nodes.
To set the refresh time
The Refresh Timer dialog appears.
The refresh time is set and takes effect.
